Netup
May 16, 2019Aspirant
Can cm1150V support voip connections?
I have a guest house that is connected to the main house with Ethernet and cable. There is no phone line to the guest house.
The main house uses a Netgear Nighthawk CM1150V modem to connect ...
- May 17, 2019
you can install Another VoIP line (such as Vonage, ooma,) in guest house but you cannot extend Comcast-Voice into guest house using Ethernet.
You can try installing high range wireless cordless phone but not sure how far your guest house is.
May 17, 2019Guru - Experienced User
Yes. It should work for that. Most modems and routers support VoIP communications.
