Netup's avatar
Netup
Can cm1150V support voip connections?
I have a guest house that is connected to the main house with Ethernet and cable.  There is no phone line to the guest house.     The main house uses a Netgear Nighthawk CM1150V modem to connect ...
  • vkdelta's avatar
    May 17, 2019
    you can install Another VoIP line (such as Vonage, ooma,) in guest house but you cannot extend Comcast-Voice into guest house using Ethernet.
    You can try installing high range wireless cordless phone but not sure how far your guest house is.
