Netup
May 16, 2019Aspirant
Can cm1150V support voip connections?
I have a guest house that is connected to the main house with Ethernet and cable. There is no phone line to the guest house.
The main house uses a Netgear Nighthawk CM1150V modem to connect ...
- May 17, 2019
you can install Another VoIP line (such as Vonage, ooma,) in guest house but you cannot extend Comcast-Voice into guest house using Ethernet.
You can try installing high range wireless cordless phone but not sure how far your guest house is.
Netup
May 17, 2019Aspirant
Ok, that's what I suspected. The wireless phone is out of range, so that leaves 3rd party voip or the cable connection if I want to use Comcast Voice. If I installed an additional cable modem with voice, I probably could get a new phone line, I will check with Comcast.
vkdelta
May 18, 2019NETGEAR Employee Retired
I think you can buy second line on your account but they will charge you. Not sure if you get some kind of discount though.
