SarahBock
Nov 11, 2016Initiate
Can I change LAN IP address from 192.168.0.1 to 192.168.100.1?
Hi all I've been asked to change my LAN IP address from 192.168.0.1 to 192.168.100.1 to avoid an IP conflict with a VPN. In the Firmware I've gone to Advanced > Setup > LAN setup and am about...
TheEther
Nov 11, 2016Guru
Just to be clear, the following won't work:
Starting IP address: 192.168.0.x
Ending IP address: 192.168.100.y
What will work is the following:
Starting IP address: 192.168.100.x
Once you apply this change, your devices will need to obtain IP addresses in the new range. For devices that use DHCP to get their IP addresses automatically, rebooting them will work. For devices that are manually configured with a static IP address, it will be necessary to manually change their address to fit in the new subnet.
- SarahBockNov 11, 2016Initiate
Thank you! Yes that was a typo. I followed your advice and it worked perfectly.
