Stalerat
Mar 10, 2022Follower
Can I connect coax cable router to ethernet socket (Sonic)
I bought NETGEAR Nighthawk Cable Modem WiFi Router Combo C7000 and it worked perfectly with Xfinity - I just plugged into the socket with coax cable. I recently installed Sonic in my apartment and th...
- Mar 10, 2022
No and yes.
You can't connect the c7000 to your sonic service.
The C7000 has a modem only mode but not a router only mode.
but you can make the c7000 into a type of access point.
You'll still need something controlling the routing through.there's a guide here if you want to try it.
Mar 10, 2022Guru - Experienced User
No and yes.
