Sbook's avatar
Sbook
Tutor
Sep 23, 2017
Can I convert a C7000 cable modem router to a bridge/
I have several AC1900 Cable Modem Routers, that I need to convert to access points that will be attached to an ethernet cable.  I still need the wifi ability.  If I turn off the DHCP, will I then be ...
  • TheEther's avatar
    Sep 23, 2017
    Turning off DHCP and using a LAN port should work.
