fnunez
Jan 16, 2021Follower
Can I select 80mhz channel for 5ghz on C7000
I currently have set the router with Optimum as my IPS. I was wondering if there is a possibility to be able to set up the 5Ghz channel to 155. Currently I have it set to 161 which falls on 20Mhz....
Jan 17, 2021Guru - Experienced User
I'm not sure if you understand how it works.
It channel overlaps. If you have it set to channel 161, it overlaps from channel 149-161.
What sets your channel width is the "up to ****" speed.
If you have it set on "up to 1300mbps" its using 80hz wide channels.
