EG18KGOLD's avatar
EG18KGOLD
Follower
Mar 02, 2020
Can I use an external firewall with the C7800 DOCSIS 3.1 and WiFI Combo?
I am trying to figure out if I can use an external firewall with the C7800 modem/wifi combo unit. Currently I have an older docsis modem in bridged mode and a firewall in between that and a nighthawk R7000. I need to upgrade to a docsis 3.1 and I like the C7800. Is it possible to have all traffic bridged to a firewall than back into the C7800 out the LAN AND WIFI? ISP ----> C7800 ----> Fortigate --->C7800 Lan/WiFi 2.4 and 5ghz ---- >wired and wireless devices C7800 https://www.netgear.com/home/products/networking/cable-modems-routers/C7800.aspx User manual http://www.downloads.netgear.com/files/GDC/C7800/C7800_UM_EN.pdf
  • michaelkenward's avatar
    michaelkenward
    You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
    Cable Modems & Routers
    I have asked the Netgear moderator to move your message.
  • > [...] Is it possible to have all traffic bridged to a firewall than
    > back into the C7800 [...]
       No.  In Cxxxx models, the connection between the modem and router
    sections is not exposed to the user.  You should be able to use a Cxxxx
    as a modem only, but you have no access to a WAN/Internet Ethernet
    interface on it, which makes using its router section as a router
    practically impossible.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    not possible.
    Buy 2 separate devices.
    CM1000 and use R7000 or upgrade to something such as RAX80 or R8000P
