aRoaringSilence
Nov 10, 2022Follower
Can I use C6300 as switch with WiFi in new building?
Good day, I recently was upgraded by Verzion to their CR1000A router. My plan is to build a she-shed and convert it into an office at the back of my property. I will run a cat7 ethernet cable from ...
Nov 11, 2022Guru - Experienced User
Does it have this capability with an easy "click this one button"? No.
But there's a workaround some have used. You can see it here:
You can try that method and if it doesn't work, look for a router with access point mode, an access point, or even a wifi extender with access point mode.
