IT1Sparks
Dec 07, 2020Aspirant
Can I use ONLY WIFI for this device? Spectrum Business Modem was installed today!
My company partnered with Spectrum Business to offer a special monthly rate with faster service (200 MBPS). I was told that I had to use the Spectrum business modem (no monthly fee) and I assumed th...
Dec 07, 2020Guru - Experienced User
Try this, set the modem up for a static IP address(should be in same IP address pool as what your host router uses), disable the DHCP server on the modem. Set up the wifi SSID name and password.
Connect the modem to the main host router using one of the modems open LAN ports..
