IT1Sparks
Dec 07, 2020Aspirant
Can I use ONLY WIFI for this device? Spectrum Business Modem was installed today!
My company partnered with Spectrum Business to offer a special monthly rate with faster service (200 MBPS). I was told that I had to use the Spectrum business modem (no monthly fee) and I assumed th...
antinode
Dec 07, 2020Guru
> [...] I had to use the Spectrum business modem [...]
An actual maker and model number would be interesting.
> [...] I assumed [...]
Always dangerous.
> [...] Should I go buy a WIFI router or can I configure this one for
> only WIFI? [...]
If your (unspecified) "the Spectrum business modem" is actually a
modem+router, and its own wireless stuff is unsatisfactory, then you
should be able to configure a C6300 as a wireless access point. See,
for example:
https://community.netgear.com/t5/x/x/m-p/1463500
Whether the performance would be satisfactory might best be
determined by experiment.
- IT1SparksDec 08, 2020Aspirant
Hello, answers to your comments. Thanks for the link, I'll try to set it up as a wireless access point. Otherwise, I'll purchase a router.
- Spectrum Model E31T2V1; DOCSIS 3.1
Always dangerous.
- Agree, rookie mistake! I had it written down to research it, but didn't get to it.
If your (unspecified) "the Spectrum business modem" is actually a modem+router, and its own wireless stuff is unsatisfactory, then you
should be able to configure a C6300 as a wireless access point. See, for example: https://community.netgear.com/t5/x/x/m-p/1463500Whether the performance would be satisfactory might best be determined by experiment.
- The Spectrum modem is not a modem/router.
- antinodeDec 08, 2020Guru
> o The Spectrum modem is not a modem/router.
Right. The (Technicolor?) E31T2V1 is a modem. You need a router to
use with it, and the C6300 can't be used that way because it has no
WAN/Internet Ethernet port.> [...] I'll try to set it up as a wireless access point. [...]
With no router, that would let you use at most one client device.
> [...] Otherwise, I'll purchase a router.
You'll need one.
