IT1Sparks
Dec 07, 2020Aspirant
Can I use ONLY WIFI for this device? Spectrum Business Modem was installed today!
My company partnered with Spectrum Business to offer a special monthly rate with faster service (200 MBPS). I was told that I had to use the Spectrum business modem (no monthly fee) and I assumed th...
antinode
Dec 07, 2020Guru
> [...] I had to use the Spectrum business modem [...]
An actual maker and model number would be interesting.
> [...] I assumed [...]
Always dangerous.
> [...] Should I go buy a WIFI router or can I configure this one for
> only WIFI? [...]
If your (unspecified) "the Spectrum business modem" is actually a
modem+router, and its own wireless stuff is unsatisfactory, then you
should be able to configure a C6300 as a wireless access point. See,
for example:
https://community.netgear.com/t5/x/x/m-p/1463500
Whether the performance would be satisfactory might best be
determined by experiment.
IT1Sparks
Dec 08, 2020Aspirant
Hello, answers to your comments. Thanks for the link, I'll try to set it up as a wireless access point. Otherwise, I'll purchase a router.
- Spectrum Model E31T2V1; DOCSIS 3.1
Always dangerous.
- Agree, rookie mistake! I had it written down to research it, but didn't get to it.
If your (unspecified) "the Spectrum business modem" is actually a modem+router, and its own wireless stuff is unsatisfactory, then you
should be able to configure a C6300 as a wireless access point. See, for example: https://community.netgear.com/t5/x/x/m-p/1463500
Whether the performance would be satisfactory might best be determined by experiment.
- The Spectrum modem is not a modem/router.
- antinodeDec 08, 2020Guru
> o The Spectrum modem is not a modem/router.
Right. The (Technicolor?) E31T2V1 is a modem. You need a router to
use with it, and the C6300 can't be used that way because it has no
WAN/Internet Ethernet port.> [...] I'll try to set it up as a wireless access point. [...]
With no router, that would let you use at most one client device.
> [...] Otherwise, I'll purchase a router.
You'll need one.
