Nomad-annie's avatar
Nomad-annie
Follower
Sep 28, 2024
Can I use Orbi RBR750 router and Nighthawk modem CM1100 bought in USA in EU
Moved to the EU and would like to use my Nighthawk CM1100 modem plus Orbi RBR750 router and satellites. Is it possible and what do I need?
  • Something to check with the perspective ISP in the EU Region that your located around to see what there requirements are for there network. Some ISPs use different equipment or don't support CM series modems. You should be able to use the Orbi system with something there though.
  • FURRYe38's avatar
  • plemans's avatar
    One issue you might have is the USA versions are region-locked. If you move to the EU, you'll want to change the region because each region has broadcast restrictions. If you can't change it, you could run afoul of their broadcast restrictions.
