Holdout
Mar 05, 2021Aspirant
Can I use the Netgear C7100V instead of Verizon Fios G3100 or G1100 ?
I am currently an Xfinity customer using the the Netgear C7100V (works fine) and am considering a switch to Fios, but do not want to rent or purchase their G3100 or G1100 router. Is this possible?
- Mar 07, 2021
the C series models are a cable modem which only works on cable ISPs. Verison is a FIOS ISP, which differs from cable.
Be sure to contact the ISP and ask them what is required for there services.
Good Luck.
Mar 07, 2021Guru - Experienced User
Good Luck.
