FAUguy
Jun 26, 2023Aspirant
Can no longer login to my CM2050V modem
Hello. I've been using a CM2050V modem that I purchased for use with Comcast a little over a year without issue. When I got it, I changed the login password, as the default password was "admin". Now...
- Jun 26, 2023
I got it to work. Had to do a few of the resets on the back, and a 2 min power down. Then was able to use the password printed on the bottom and login.
But when I went to change it to the password that I had been using (6 lower case characters and several numbers) it said that one character now had to be capitalized or use a special character. So I did the same password as before but capitalized the first letter. Now I can log in. But something must of changed, for my old password not to log in, had to factory reset, login with the defaults password, then use when trying to change to my old password I had to capitalize the first letter.
Jun 26, 2023Guru - Experienced User
Can you try a factory reset with out the ISP Coax cable connected. Press the reset button for 10 seconds then release. Then try to log in. If you can get in, then re-connect the ISP coax cable to the modem.
FAUguy
I've tried that, disconnecting the coax, pressing the Rest button for 30 seconds, let it reboot, still can't log in. I've tried my phone, laptop, and wired PC and non of them will log in. It was working just fine last week.
- FURRYe38Jun 26, 2023Guru - Experienced User
Only thing I can think of is that the ISP sent some config down to the modem and blocked access. Might ask the ISP about this. I've not seen CC or XF lock out user access but anything is possible. Possible some configure got sent by accident. Might has them to check there config file and re-send it and factory reset it from there side.
- FAUguyJun 26, 2023Aspirant
I remember reading a few years ago that Comcast did push a firmware to some Motorola modems and users could no longer log in. I've posted this question in the Xfinity Support forums as well. If I can't get it working, then I'll end up having to call, bi their phone support (forwarded to outside the US) is pretty bad.
Good Luck. 🙄
