Tansta27
May 29, 2020Aspirant
Can not connect to internet when directly connected to modem via Ethernet
All lights are solid green expect for the Ethernet light which is blinking green. Can sometimes get internet to do a basic google search to run the speed test and I get my normal download but 0 upload...
May 30, 2020Guru - Experienced User
Any splitters, amplifiers, attenuators in the line? if so, remove them.
Take a screen snip of the cables connections page and post it back here.
Preferrably, move the modem to right where the coax enters the home and directly connect it.
the isp might need to check the line.
