F33SKIPPER
Feb 05, 2017Aspirant
Can not connect to WiFi. Works fine on Ethernet cable while plugged into the back of the Router!
I am new at this stuff, so please cut me some slack folks? I think that during an Win.10 update something went wrong and all of my devices lost WiFi connectivity IE, Lap Top, Desk Top, 2 Tabs and...
DarrenM
Feb 07, 2017Sr. NETGEAR Moderator
Hello F333SKIPPER
Can you provide what model your modem is. Also when you factory reset the device by holding the reset button down for 10 seconds the default login should be admin/password.
DarrenM
- F33SKIPPERFeb 08, 2017Aspirant
Thanks DarrenM for your response! Here is the info no the Modem! It is a Motorola, SURFboard, Model # SB5101.
WiFi was working fine till I Reset the Router.
I am aware that the user name is now “admin” and the password is “password”.
My problem is that I can not remember how to tell my computer of this change and get the two of them to talk to each other! Tried to follow the manual but could not understand the Tec. Lingo. :(
- DarrenMFeb 08, 2017Sr. NETGEAR Moderator
What is the model of the Netgear product that you have?
DarrenM
- F33SKIPPERFeb 09, 2017Aspirant
DarrenM, Sorry, I thought that all the info had been saved when I Registered!
Here is pretty much every thing on my equipment.
MAKE: Netgear Wireless Router,
MODEL: WGR614v7-VC,
SPEED: 54 Mbps,
SER#: 1MU1987G02C56,
MAC: 0026F203EA6E,
Computer: Win 10, 64 Mbps.THANKS AGAIN FOR YOUR HELP DARREN:)
