62BT409
Mar 31, 2019Follower
Can not get into my C6300-100NAS
I have typed both the items in the brower that is nneded, then hit the enter key. It drops the "http://" and tells me
"This page isn’t working
routerlogin.net sent an invalid response.
Apr 01, 2019Guru - Experienced User
you can try logging on via the IP address. Default is usually 192.168.1.1 or 192.168.0.1. but you can find it by this option:
Once you have that address, type it into your browser and it should bring you to you're devices page.
here's a specific manual for the C6300-100nas
http://www.downloads.netgear.com/files/GDC/C6300/C6300_UM_17Nov2015.pdf
