Matthew2r35
Jul 31, 2020Tutor
Can not log into router
Since the new edge upgrade I can not Log into router.
Matthew2r35
Jul 31, 2020Tutor
No I tried Chrome and edge it will not let me in. I set the router to factory setting and it still wont let me in.
Jul 31, 2020Guru - Experienced User
Even with a wired connection? Using 192.168.0.1 or 192.168.100.1?
Try this, disconnect the coax cable from the modem. Press the reset button for 15 seconds then release. Have a wired PC connected to the back of the modem on a LAN port. Try accessing the modems web page at 192.168.100.1 or 192.168.0.1...
- Matthew2r35Jul 31, 2020TutorI used fire fox and it worked. Thanks for your help!
- FURRYe38Aug 01, 2020Guru - Experienced User
Glad you got in with FF.
Please mark your thread as solved so others will know.
