SW2424
Dec 23, 2015Follower
Can not reset N300 Model C3000 to factory settings
have never changed factory settings, can't login with user: admin and password: password also cannot reset N300 Model C3000 to factory settings have held the reset button on bottom as describ...
DarrenM
Dec 29, 2015Sr. NETGEAR Moderator
Hello Sw2424
If the factory reset is not working might be out of luck no other way to reset the login. If the modem is still under warranty contact netgear phone support see if it can be RMA
DarrenM
