Retired_Member
Mar 25, 2019Can someone please explain to me the difference between these two switches GS305 and GS105NA?
Hi, I'm looking for a 5 port switch and I found two models from Netgear that I'm interested to use at my home with my desktop, Nvidia Shield, etc... I looked the specs and my non-technical expertise ...
antinode
Mar 25, 2019Guru
> [...] I looked the specs [...]
Which "the specs"? Visit http://netgear.com/support , put in your
model number(s), and look for Documentation. Get the Product Data
Sheet(s).
I don't see any significant differences. Length of warranty?
> Is the difference that the GS105NA can connect up to 2gibit per port
> and the GS305 only makes up to 1gbit?
No. Both have 1Gb/s ports.
There's a more appropriate forum for such devices:
https://community.netgear.com/t5/x/bd-p/business-unmanaged-switches
Retired_Member
Mar 25, 2019Thank you for pointed the appropriated space for this discussion.
