aanders50
Aug 04, 2019Guide
Can the AC 1750 be used as just a router?
I am looking at getting the CM1100 (modem only) https://www.netgear.com/home/products/networking/cable-modems-routers/CM1100.aspx But I want to try and find a use for my current router-modem which...
antinode
Aug 04, 2019Guru
> [...] the AC1750. [...]
"AC1750" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label for the actual model
number.
> Model: C6300|AC1750 Cable Modem Router Docsis 3.0
"C6300" is a model number. Is that accurate?
> [...] Can this be used as the primary router or no?
Only if you could find an accessible WAN/Internet Ethernet port on
the thing. So, no.
> [...] But I want to try and find a use for my current router-modem
> which is the AC1750. [...]
There would be some chance of using a C6300 as a wireless access
point (attached to some other router), however. See, for example:
aanders50
Aug 05, 2019Guide
Thank you for the info and guidance on speed versus model. (and yes, it is the c6300)
And yea, I was wondering that too, since it does not have any sort of "input" for ethernet, just co-ax. :(
