aanders50
Aug 04, 2019Guide
Can the AC 1750 be used as just a router?
I am looking at getting the CM1100 (modem only) https://www.netgear.com/home/products/networking/cable-modems-routers/CM1100.aspx But I want to try and find a use for my current router-modem which...
Aug 05, 2019Guru - Experienced User
Can be used in bridge mode as a modem only or in gateway mode which is modem/router combo mode. There is no router only mode.
aanders50 wrote:I am looking at getting the CM1100 (modem only) https://www.netgear.com/home/products/networking/cable-modems-routers/CM1100.aspx
But I want to try and find a use for my current router-modem which is the AC1750. Can this be used as the primary router or no?
Thanks!
