paliys
Aug 05, 2020Follower
Can the CM1200 / CM1100 Cable Modem Replace my Telstra NBN Modem?
NBN supplied me with their Arris CM8200 Modem and I want to upgrade my modem only. (not router)
Is the CM1200 / CM1100 Compatible with Telstra NBN Provider?
If not, what other modems are compatible with Telstra NBN?
Which Australian ISPs support Netgear Modems?
Do I need to configure anything else?
Thanks
1 Reply
You'll need to ask the ISP about that. They will have this information.
Good Luck.
