HomeTown
Mar 29, 2020Aspirant
Can you help me improve my wifi connections on a C7100 Nighthwawk AC1900 WiFi Cable Modem Router?
Recently all my wireless devices (tablet, laptop, phones) are connecting at much lower speeds (90 Mbps) compared to my wired PC (550 Mbps.) Is there anything I can do to get my wifi speeds back up? ...
Mar 29, 2020Guru - Experienced User
Set 20/40Mhz Coexistence to 40Mhz only.
- HomeTownMar 29, 2020Aspirant
I'm using Auto on 2.4Ghz but it's using 11. 5Ghz is in channel 153.
I do have about 7 Wifi neighbors nearby wth about 14 wifi devices in range.
I do not see where I can set Coexistence.
I did have Comcast do a modem reset.
- HomeTownMar 30, 2020Aspirant
I attached a picture from a WiFi Channel Scanner.
