SBMongoos
Sep 20, 2019Aspirant
Cannot access internet when directly connected to 1150V
 Hello...  Just replaced with modem (it died) with this 1150v. Setup went fairly easy. However, when I connect to it directly I cannot get onto the internet. If I connect to my WiFi router I can get a...
- Sep 21, 2019After connecting your PC directly to the modem, are you turning OFF the modem for 30 seconds then back on then check to see if the PC gets a public IP address and then has access to the internet? This should work here...Sometimes i may take a miniute or two for the PC to get fully connected with the modem...
Sep 20, 2019Guru - Experienced User
This modem is a modem only. It does not have a DCHP server or any wifi support. It can only support 1 PC or external router connected to it. So a wired PC should get internet access thru the modem if directly connected to the modem.
Have you connected a external router to the back of the Modem? Then connect ALL wired and wireless devices to the router?
- SBMongoosSep 20, 2019AspirantEverything works fine when the Asus WiFi router is connected to the modem. Wired and wireless. However, if I connect a PC directly to the modem I cannot get access to the internet. I've tried a ipconfig/release and ipconfig/renew from the CMD prompt but no go. Just get the self assigned IP address from Win10. Once I do the release I'm not able to do the renew as it doesn't seem to identify the modem as a device I can connect to. Comcast is of no help at all. Several hours and the people there don't seem to understand. WT...! - FURRYe38Sep 21, 2019Guru - Experienced UserAfter connecting your PC directly to the modem, are you turning OFF the modem for 30 seconds then back on then check to see if the PC gets a public IP address and then has access to the internet? This should work here...Sometimes i may take a miniute or two for the PC to get fully connected with the modem... - SBMongoosSep 21, 2019AspirantNo I sure wasn't. Duh...I should have known better since this doesn't have DHCP. Thought I read that it did. No matter. I'm connected directly and on the internet after doing a brief disconnect from power. Now if Comcast can figure out how to get my access back to xfinitywifi hots spots. Since I swapped out the modem I've lost access and they're quite confused.
