SBMongoos
Sep 20, 2019Aspirant
Cannot access internet when directly connected to 1150V
 Hello...  Just replaced with modem (it died) with this 1150v. Setup went fairly easy. However, when I connect to it directly I cannot get onto the internet. If I connect to my WiFi router I can get a...
- Sep 21, 2019After connecting your PC directly to the modem, are you turning OFF the modem for 30 seconds then back on then check to see if the PC gets a public IP address and then has access to the internet? This should work here...Sometimes i may take a miniute or two for the PC to get fully connected with the modem...
SBMongoos
Everything works fine when the Asus WiFi router is connected to the modem. Wired and wireless.
However, if I connect a PC directly to the modem I cannot get access to the internet. I've tried a ipconfig/release and ipconfig/renew from the CMD prompt but no go. Just get the self assigned IP address from Win10. Once I do the release I'm not able to do the renew as it doesn't seem to identify the modem as a device I can connect to. Comcast is of no help at all. Several hours and the people there don't seem to understand. WT...!
Sep 21, 2019Guru - Experienced User
- SBMongoosSep 21, 2019AspirantNo I sure wasn't. Duh...I should have known better since this doesn't have DHCP. Thought I read that it did. No matter. I'm connected directly and on the internet after doing a brief disconnect from power. Now if Comcast can figure out how to get my access back to xfinitywifi hots spots. Since I swapped out the modem I've lost access and they're quite confused.
