SBMongoos
Sep 20, 2019Aspirant
Cannot access internet when directly connected to 1150V
 Hello...  Just replaced with modem (it died) with this 1150v. Setup went fairly easy. However, when I connect to it directly I cannot get onto the internet. If I connect to my WiFi router I can get a...
- Sep 21, 2019After connecting your PC directly to the modem, are you turning OFF the modem for 30 seconds then back on then check to see if the PC gets a public IP address and then has access to the internet? This should work here...Sometimes i may take a miniute or two for the PC to get fully connected with the modem...
Sep 23, 2019Guru - Experienced User
Ok glad you go that solved.
Hopefully ISP will get it all working for you.
Mark your post as solved so others will know..
Good Luck.
