plwj
Apr 15, 2020Tutor
Cannot bridge Linksys Router with my NetGear C700 Modem/Router.
I am trying to extend our wireless and wired network to other parts of our home to support new wired devices and improve our wireless coverage. I have been reviewing numerous web and community sites ...
- Apr 23, 2020
Good News!
I now have my Linksys setup as a bridged device behind the NetGear C7000 to extend my wired and WiFi connectios.
I was trying to make too many changes at the same time on my network.
- While testing the bridged Linksys device, I also add an ooma telephone device to my wired network.
- With two ports on back of the ooma device and 4 ports (already used) on back of my NetGear router, I move one of the Netgear connection to the back of the ooma device and connected the ooma device to the freed up port on the router.
- The devices worked coming out of the ooma device, but what I did not realize was that the ooma device has its own DNS Server (172.27.35.x), which changed my device IP address behind it from the 192.168.0.x addresses that I expected.
- With the IP Address changes, I could not find these devices on my network in the 192.168 range.
Thanks for your input on this issue!
Apr 15, 2020Guru - Experienced User
Having two routers on the same line will be problematic.
I would first bridge the C series modem to disable the router here, then connect the Linksys router normally in router mode to the modem.
Please contact Linksys for additional help and information regarding there router.
Good Luck,.
plwj
Apr 17, 2020Tutor
The NetGear C7000 is a modem/router so it has to be my master.
- antinodeApr 17, 2020Guru
"bridge" is a term with (too) many meanings, and probably none of
them applies in this case.> I am trying to extend our wireless and wired network [...]
The most likely path would be to configure the add-on Linksys EA6900
as a wireless access point. (I assume that that's possible; perhaps the
relevant product documentation explains how.) That should put all your
client devices on one LAN subnet ("192.168.0.*"), and allow everyone to
talk to everyone else.- plwjApr 17, 2020Tutor
Thanks for that.
I also need to extend my wired network to connect Roku and wired printer in upstairs room.
- FURRYe38Apr 20, 2020Guru - Experienced User
Check with the Linksys Mfr to see what can be configured on the Linksys router. Not all routers support bridge or repeater or extender features.
plwj wrote:Thanks for that.
