VasileiosSiokos
Mar 09, 2022Follower
Cannot Connect to CISCO VPN With my CAX80 rOUTER
Good morning, My wife is using CISCO VPN for her work and she cannot connect to it. She is getting an error message to check connectivity and server address. We have XFINITY and a Netgear CAX80 m...
Mar 09, 2022Guru - Experienced User
have you checked with the vpn provider to see if theres any certain port that needs to be opened?
Or if she has any security software on her laptop thats blocking it?
Usually we have you start with the vpn provider to get the requirements and to make sure it isn't a computer issue
