Nesto1000's avatar
Nesto1000
Cannot connect to devices on my modems WiFi
Hello all,   I have a bit of a weird issue that I can't seem to enter the correct terms in google for a fix, so please bare with me. Below is a bulletpoint list of my setup: I have Xfinity gigabi...
  • plemans's avatar
    Nov 24, 2019
    If the xfinity device is in router mode and the nighthawk as well, you'll be in a double nat. This will cause the exact situation you're having. Easiest fix? place the nighthawk in AP mode. it turns over routing functions to the xfinity device.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Why can't you get the cm1000 working?
