Cax80istrash
May 21, 2022Aspirant
Cannot connext to network
Recent power outage here and my cax80 will not let me connect to the network via wifi or ethernet now. I've tired a factory reset, wps buttons or wifi buttons do not light up or work. I've resorted to...
May 22, 2022Guru - Experienced User
After pressing the reset button for 10 seconds with the CAX80 connected to the ISP coax line, can you access the modems setup web page 192.168.1.1 at all with a wired PC and web browser?
How long have you had the modem for?
Cax80istrash wrote:
Recent power outage here and my cax80 will not let me connect to the network via wifi or ethernet now. I've tired a factory reset, wps buttons or wifi buttons do not light up or work. I've resorted to using my old c7000v2 and everything works fine, just not as fast as the cax80 when it worked. Cax80 I guess is destined for the trash... Anywords of wisdom?
Cax80istrash
May 28, 2022Aspirant
No I can not as I just attempted to with my laptop. I've had the modem now for maybe 6 months now I would say.
- FURRYe38May 28, 2022Guru - Experienced User
Can you try pressing the reset button for 1 full minute then release...
Also might try doing the 30/30/30 reset process.
- Cax80istrashMay 29, 2022AspirantGave that a shot with nothing other than the power connected and still not able to get onto the network.
- FURRYe38May 30, 2022Guru - Experienced User
I'll recommend you reach out to a forum moderator and ask for there help. Seems like a RMA maybe needed here.
