Cax80istrash
May 21, 2022Aspirant
Cannot connext to network
Recent power outage here and my cax80 will not let me connect to the network via wifi or ethernet now. I've tired a factory reset, wps buttons or wifi buttons do not light up or work. I've resorted to...
Cax80istrash
May 28, 2022Aspirant
No I can not as I just attempted to with my laptop. I've had the modem now for maybe 6 months now I would say.
May 28, 2022Guru - Experienced User
Can you try pressing the reset button for 1 full minute then release...
Also might try doing the 30/30/30 reset process.
- Cax80istrashMay 29, 2022AspirantGave that a shot with nothing other than the power connected and still not able to get onto the network.
- FURRYe38May 30, 2022Guru - Experienced User
I'll recommend you reach out to a forum moderator and ask for there help. Seems like a RMA maybe needed here.
- Cax80istrashJun 05, 2022AspirantSounds good I'll reach out to one of those moderators. To figure out the rma process.
