Fred87
Apr 07, 2020Aspirant
cannot get my N600 WiFi Cable Model Router to work
I have just started installation and cannot get the Online LED to light solid green. It say wait 10 minutes but i have waited hours and nothing. Do I have a defective modem ?
Apr 07, 2020Guru - Experienced User
Did you activate it with your ISP?
Fred87
Apr 08, 2020Aspirant
Thanks for your reply...
I am not a techy ...so i don't know what ISP stands for...
at first i was told i had to have ATT get it going but after they did i found out what i thought was the unit working was i was only getting my wireless wifi working not Netgear unit..
then i was told I need a Coax cable but when i bought it at Best Buy i was told i did not...so next step is to get one and try that...
thanks again..
- FURRYe38Apr 08, 2020Guru - Experienced User
ISP = Internet Service Provider.
Review all user manuals and quick installation guides for installation of modems.
Fred87 wrote:Thanks for your reply...
thanks again..
- plemansApr 08, 2020Guru - Experienced User
thanks again..
Your service provider is ATT? I didn't know that att had cable modem service. If you've got att, you'll need to check with them on a compatible modem/router.
