Jccasey22
Dec 16, 2021Follower
Cannot reach 1 website only
I am unable to reach one website only, my company's website, at this time. I have done a full factory reset on my NightHawk AC1750 C6300v2 as well as several full resets of my computer. I am using Ch...
Apr 09, 2022Guru - Experienced User
Any progress on this?
Jccasey22 wrote:
I am unable to reach one website only, my company's website, at this time. I have done a full factory reset on my NightHawk AC1750 C6300v2 as well as several full resets of my computer. I am using Chrome on macOS. This issue has come up before, but usually only lasts a few minutes. It has been blocking my access to my website for a full 24 hours now.
I have changed DNS settings, and cannot find a way to see if this is a firewall situation within the Nighthawk app or in the advanced settings on netgear.
To make sure it wasn't a wifi issue or a mac issue, I have plugged a separate PC into the ethernet cord and have the same issue.
The website is working find and is accessibel to my entire team, and also works fine if I access it through my data plan.
Is this a faulty router issue?
