vmwnek
Sep 01, 2017Guide
Cannot reserve static IP addresses
When I try to add a reservation for a Static IP address, I get this error each time. I cannot set static ips. The connection was reset The connection to the server was reset while the page was...
DarrenM
Sep 07, 2017Sr. NETGEAR Moderator
Have you tried to do this in chrome or IE?
DarrenM
vmwnek
Sep 07, 2017Guide
I have tried all 3 browsers. I use Firefox.
- DarrenMSep 08, 2017Sr. NETGEAR Moderator
are you doing this on a PC connected directly via ethernet.
DarrenM
- vmwnekSep 08, 2017GuideYes.
This is one of 2 exact same modems I purchased. One works great.
This one has this problem and also the dlna will not recognize a hard drive that works on the other modem just fine.
I think it is a firmware issue, but Netgear does not update firmware, and Suddenlink does not update firmware for those customers who use their own equipment.
The whole thing is one big circle jerk.
