JayG2
Mar 24, 2016Aspirant
Cannot Stay Connected to 3700; Cannot Change Channel
Two Querstions: 1. When I browse to the web administration page of my C3700-100NAS and specify a new 5G channel, the web site shows the new channel on the channel display, but the old channel rem...
JayG2
Mar 31, 2016Aspirant
Hi Darren-- My ISP is Cox. How could that have anything to do with the inability of the Surface Pro 4 internal Marvell Wi-Fi adapter to connect to the C3700. Even if Cox vaporized entirely, the Surface Pro 4 should still connect to the C3700, shouldn't it? Also, if I cannot connect, as I said, why do you ask if I am connected using IPV6?
DarrenM
Apr 01, 2016Sr. NETGEAR Moderator
Hello JayG2
I was asking the ISP because of the firmware. Different ISPs are on different firmware Cox is on a older firmware compared to TWC and Comcast but I have no info on when the next release for Cox is since we send the ISPs the firmware and they put it through a certification and then release it when they want to. I have read that the surface has some wifi issues I did find a article of all the stuff you can try.
DarrenM
