HenryLeeChi
Jul 23, 2020Tutor
Can't access 192.168.100.1
Hello. I just got a new modem CM1100 and I can't seem to access 192.168.100.1 on my pc. I can access it perfectly fine on my cellphone though. Default gateway seems to point to my router 192.168.1.1...
Jul 23, 2020Guru - Experienced User
What Mfr and model# router do you have connected between the CM modem and PC.
Can you connect to the modem directly with a PC?
HenryLeeChi
Jul 23, 2020Tutor
the router is a netgear R7000P. I can connect directly but I still won't be able to access 192.168.100.1. I have already tried unpluging, disconnecting the coax, connecting directly to my pc, and then plugging back in with the coax disconnected. That doesn't allow me in 192.168.100.1 either.
- FURRYe38Jul 23, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
- HenryLeeChiJul 23, 2020Tutor
Just tried that and I still can't log into 192.168.100.1 on my pc
factory reset my modem AND my router and now it seems to work!
