HenryLeeChi
Jul 23, 2020Tutor
Can't access 192.168.100.1
Hello. I just got a new modem CM1100 and I can't seem to access 192.168.100.1 on my pc. I can access it perfectly fine on my cellphone though. Default gateway seems to point to my router 192.168.1.1...
Jul 23, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
HenryLeeChi
Jul 23, 2020Tutor
Just tried that and I still can't log into 192.168.100.1 on my pc
- HenryLeeChiJul 23, 2020Tutor
factory reset my modem AND my router and now it seems to work!
- FURRYe38Jul 23, 2020Guru - Experienced User
I would either make contact with NG support or get you another modem. Seems like the modem maybe in a bad state.
