spocentek
Sep 02, 2021Tutor
Can't access C7100V setup AND can't bypass smart wizard/genie
The device: Netgear C7100V, firmware revision V2.01.45 Synopsis: The "Smart Wizard"/"Genie" screen doesn't work AND I can't get around it using the published bypass. I've tried it with four d...
- Sep 11, 2021
Summary for everyone who might find this useful:
The initial problem was a C7100V which wouldn't execute the "Wizard"
in a web browser AND which wouldn't allow bypass of the Wizard by using
the URLs listed in the documentation (and here). The router worked, however:
that is, when plugged into a live cable connection it provided Internet,
phone and TV service. So the only issue was that I couldn't configure it.Lots of testing with different browser/OS combinations got nowhere. Symptoms
didn't change whether it was on a live cable connection or just sitting on
a desk. Finally -- with help from people here -- the solution was:1. Reset it while it's powered on and hold the button for 30 seconds.
(Page 124 of the manual, document C7100V_UM_EN.pdf, says 7 seconds. That's
apparently not long enough, go for 30 seconds. The lights on the front
will flash at somewhere around 25-30 seconds.)2. Connect a network cable between the C7100V and your laptop/desktop.
No other connections: no coax on the C7100V, no wifi on your laptop/desktop.3. Use a brand-new installation of a web browser. I had success with Firefox
on Ubuntu (finally). If you can't make the Wizard work: try another browser
on another OS. Use as vanilla browser configuration as possible: no
extensions, no fancy options.Notes:
I don't believe browser extensions were the issue (I had them turned
off or not installed in all of the combinations that I tried) but I do
think there might be a subtle interaction between the Wizard and the
default configuration of some browser/OS combinations I used that
MAY be the root cause of my problemI never did get the bypass URL to work. Why is still an open question,
but because the C7100V's onboard web server returns a custom 404, I think
the problem is on the C7100V.
Sep 08, 2021Guru - Experienced User
Either way, glad you have it working!
If you your response as solved, it might help the next person with that issue
spocentek
Sep 11, 2021Tutor
Notes:
