BryanBalli
Nov 06, 2016Aspirant
Cant access Login Page when connected via ethernet
I have purchased a PETZI cam. It is not connecting... my troublleshooting has led me to confirm that the modem is set up in b/g/n wirelss mode (among other things), that require I log into the router...
BryanBalli
Nov 17, 2016Aspirant
Thanks for the reply Darren. I have confimred my IP addy through terminal as 100.66.101.1, and am still unable to connect... I get "This site can't be reached". I also tried 192.168.100.1 and get the same message. Any other ideas on how I can troubleshoot this issue?
DarrenM
Nov 18, 2016Sr. NETGEAR Moderator
Hello BryanBalli
From the sounds of the Ip address you linked the modem is acting like its stuck in modem only mode you could try to factory reset again but make sure you are holding the reset button for at least 10 seconds.
DarrenM
