jkmcc13
Jul 15, 2015Aspirant
Can't access N450 (CG3000Dv2) Router GUI
Hello, I just got my new mediacom internet hooked up and cannot get my wifi to work. When I plug into the modem/router with a cat5 i get internet, but I can't connect anything via wifi. I have it tur...
bigbruise
Dec 14, 2015Aspirant
old post I know...but I'm trying to set this same model in bridge mode and don't see it in the router settings. can you direct me to a page with instructions on setting this model in bridge mode?
DarrenM
Dec 14, 2015Sr. NETGEAR Moderator
Hello bigbruise
There is no bridge mode on this modem but you can try to disable the DHCP server which is Located in the LAN Ip under advanced. this should allow it to be just a AP.
DarrenM
