jkmcc13
Jul 15, 2015Aspirant
Can't access N450 (CG3000Dv2) Router GUI
Hello, I just got my new mediacom internet hooked up and cannot get my wifi to work. When I plug into the modem/router with a cat5 i get internet, but I can't connect anything via wifi. I have it tur...
jkmcc13
Jul 16, 2015Aspirant
Babylon5 wrote: If you see your Public IP address at the computer when connected via the ‘3000, then it may be that the ‘3000 is configured in Modem Only (Bridged) mode.
ok, I got into the GUI using 192.168.100.1
my techie friend says that my modem is connected directly to the internet (no firewall) and that the modem/router is not in NAT mode. when in the GUI if I check the "enable NAT" box and apply, the modem reboots and there is no change. I have done this a few times with no luck. I have also done factory resets with no change.
any idea why the NAT won't stay enabled?
