redxmark
Apr 19, 2016Follower
Can't access routerlogin.net/.com/192.168.0.1/192.168.1.1
I wanted netgear router works as a bridge so I disable "Router Mode" after I apply the settings I cannot access router.net, no wireless but ethernet cable works.
I try reset router and didn't work
1 Reply
In bridge mode, the Netgear router will get an IP address from the main router using DHCP. Log onto your main router and look up the IP address it assigned to the Netgear router. Use that IP address to log into the Netgear router.
