NehalModi's avatar
NehalModi
Cant access tabs using laptop
HI,
Ealrlier i was able to login to my router using my laptop. But suddenly since 2 months though i am able to login to my Router but i am unable to access tabs that is on left side.When i try accessing tab it shows weired screen .I tried using another laptop and its same problem , also i tried another browser still no luck.
I can access Router and make changes using my android phones , Ipad , Iphone but not on laptop.
I reset router to factory default twice but no luck. Can somebosy help me out whats the exact problem here .
Router Model : N-C3700
Nehal Modi
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello NehaiModi
    Do you have some type of anti virus on your pc that could be blocking these settings since you said you can access them on your phone.
    DarrenM
    • NehalModi's avatar
      NehalModi
      It was working fine with Antivirus as well. But i tried disabling it but still problem is the same .......Even i tried login in using another laptop but still problem is the same.
      Any suggestion would appreciate .
