Bubenduben's avatar
Bubenduben
Follower
Aug 30, 2019
Can't boot Bad Data CRC
Hello,
i have same issue like here:
https://community.netgear.com/t5/Stora-Legacy/NAND-corrupted-can-t-get-passed-uboot/td-p/402403
__ __ _ _
| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** MARVELL BOARD: RD-88F6281A LE
U-Boot 1.1.4 (May 30 2011 - 09:26:20) Marvell version: 3.4.15
U-Boot code: 00600000 -> 0067FFF0 BSS: -> 006CEE60
Soc: MV88F6281 Rev 3 (DDR2)
CPU running @ 1000Mhz L2 running @ 333Mhz
SysClock = 333Mhz , TClock = 200Mhz
DRAM CAS Latency = 5 tRP = 5 tRAS = 18 tRCD=6
DRAM CS[0] base 0x00000000 size 64MB
DRAM CS[1] base 0x04000000 size 64MB
DRAM Total size 128MB 16bit width
Flash: 0 kB
Addresses 8M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (8M - 7M): Done
NAND:256 MB
CRC in Flash: c899e7d0, Calculated CRC: c899e7d0
CPU : Marvell Feroceon (Rev 1)
Streaming disabled
Write allocate disabled
Module 0 is RGMII
Module 1 is TDM
USB 0: host mode
PEX 0: interface detected no Link.
Net: egiga0, egiga1 [PRIME]
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x100000, size 0x300000
Reading data from 0x3ff800 -- 100% complete.
3145728 bytes read: OK
## Booting image at 00800000 ...
Image Name: Linux-2.6.22.18-Netgear
Created: 2011-05-26 15:05:01 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2789276 Bytes = 2.7 MB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... Bad Data CRC
Is some way to upload image via TFTP? Where can i download uImage.netgear?
