bradleyakapatty
Jul 08, 2020Aspirant
Can't change DNS servers on Netgear C6300
i'm trying to change my DNS Sever to work with my raspberry pi 4 but i keep getting this error "internal fail! fail to make the requested change" why can't i simply change this?! C6300 Firmwar...
- Jul 13, 2020
Well all FW for Cable ISPs has a hand in wnat NG gives them so ISP may have there own modifications before pushing out to users modems.
One reason why I prefer modem only units then install a external wifi router. More control over what ISPs don't need to have. :smileywink:
Jul 09, 2020Guru - Experienced User
Disconnect the COAX cable from the modem. Factory reset the them and setup from scratch. Go in with a PC and web browser and see if you can change the DNS addresses. Sometimes DNS maybe controlled by the ISP and they put restrictions on this. Review the user manual about changing DNS addresses.
bradleyakapatty
Jul 10, 2020Aspirant
ill have to try this on the weekend because i work form home right now.
i really should ask if anyone knows about raspberry pi 4 and pi-hole? because this is my main goal to get this running an working correctly and wish i knew more about networking because this part is killing me.
ill keep in touch on my status too.
- antinodeJul 10, 2020Guru
In some cases, describing the actual problem which you are trying to
solve can be helpful. If I were doing a forum/Web search for relevant
material, for example, I might include "DNS" and "Pi-hole" in the search
terms. ("Raspberry Pi" is not as important as "Pi-hole", and I would
not expect that including "4" in such a search would be helpful.)Answering questions posed here might also be helpful. For example:
> "Can't change DNS servers" to _anything_ else, or only to some device
> on your LAN?If it won't let you make _any_ changes (like, say, to "8.8.8.8"),
then that's a different problem from not accepting a LAN-subnet address."Can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.On the bright side, you did include the error message in your first
post.- bradleyakapattyJul 11, 2020Aspirant
i already said i get error "internal fail! fail to make the requested change"
- FURRYe38Jul 11, 2020Guru - Experienced User
What DNS address are you trying to input?
Seems the modem isn't liking the address as it's saying it's an "invalid address".
bradleyakapatty wrote:i already said i get error "internal fail! fail to make the requested change"
