bradleyakapatty
Jul 08, 2020Aspirant
Can't change DNS servers on Netgear C6300
i'm trying to change my DNS Sever to work with my raspberry pi 4 but i keep getting this error "internal fail! fail to make the requested change" why can't i simply change this?! C6300 Firmwar...
- Jul 13, 2020
Well all FW for Cable ISPs has a hand in wnat NG gives them so ISP may have there own modifications before pushing out to users modems.
One reason why I prefer modem only units then install a external wifi router. More control over what ISPs don't need to have. :smileywink:
bradleyakapatty
Jul 12, 2020Aspirant
Yeah I even reset it twice and same issue again with the error like i said.
But pi-hole gave me is IPv4 192.168.0.61 like the pic shows that i uploaded.
i'm suposed to use the IPv4 and set to the DNS server but thats my issue, that can't change it
-set it to the 1st DNS Server(or both lines same IP) click apply, "internal error" or "invaild IP address"
Jul 12, 2020Guru - Experienced User
So what happens if you input default ISP DNS that comes down from the ISP?
Possible that this model modem doesnt' support LAN Side DNS addresses. :smileyfrustrated:
- bradleyakapattyJul 12, 2020Aspirant
when i try to change it, i get the error and it just does back to its default IP.
209.18.47.63
uploaded pic the default gives me - FURRYe38Jul 12, 2020Guru - Experienced User
Is that someting that comes from your ISP?
Wondering if this modem modem and your ISP have DNS locked in.
- bradleyakapattyJul 12, 2020AspirantI guess so, it's what default settings go to. I never change anything but both WiFi name's and everything else is by default. And if I call spectrum about DNS server I'm sure they will be clueless and have no idea what I'm talking about. But I guess I'll try.
- bradleyakapattyJul 12, 2020AspirantYou could be right about ISP. If I'm right the firmware version is from my ISP so could be locked from them like you said😒
- FURRYe38Jul 13, 2020Guru - Experienced User
- bradleyakapattyJul 13, 2020Aspirant
i just got back from spectrum my ISP and i'm not 100% they knew what i talking about because the lady just looked something up and said we don't block anything your DNS thats on a server. but i guess netgear c6300 is just piece S*** and ill either buy another modem or wifi router thats not from netgear.
Good Luck.
- bradleyakapattyJul 14, 2020AspirantThank you for your help as well 👍
- antinodeJul 14, 2020Guru
> don't block anything your DNS thats on a server. [...]Sounds to me as if the agent didn't understand that the problem is
not with DNS itself, but with setting the DNS server option on the C6300
modem+router.The question is not whether their network is blocking anything (DNS),
but whether their provisioning of your C6300 prevents you from changing
its DNS server settings. Some low-level support flunky may not know
this, so you got the answer to some other question, instead.> [...] i[']ll either buy another modem or wifi router that[']s not from
> netgear.A cable-TV-type ISP has an amazing amount of control over the devices
which are connected to its network. Much of that is related to DOCSIS,
not Netgear, so I would not bet that changing vendors would help.
Changing to a separate unit for the cable modem might help. The DNS
server choice is a router question, not a modem question, so a separate
router would be more immune to goofy ISP policies limiting its options.
