bradleyakapatty
Jul 08, 2020Aspirant
Can't change DNS servers on Netgear C6300
i'm trying to change my DNS Sever to work with my raspberry pi 4 but i keep getting this error "internal fail! fail to make the requested change" why can't i simply change this?! C6300 Firmwar...
- Jul 13, 2020
Well all FW for Cable ISPs has a hand in wnat NG gives them so ISP may have there own modifications before pushing out to users modems.
One reason why I prefer modem only units then install a external wifi router. More control over what ISPs don't need to have. :smileywink:
bradleyakapatty
Jul 12, 2020Aspirant
You could be right about ISP. If I'm right the firmware version is from my ISP so could be locked from them like you said😒
Jul 13, 2020Guru - Experienced User
- bradleyakapattyJul 13, 2020Aspirant
i just got back from spectrum my ISP and i'm not 100% they knew what i talking about because the lady just looked something up and said we don't block anything your DNS thats on a server. but i guess netgear c6300 is just piece S*** and ill either buy another modem or wifi router thats not from netgear.
- FURRYe38Jul 13, 2020Guru - Experienced User
Good Luck.
- bradleyakapattyJul 13, 2020AspirantThank you for your help as well 👍
- antinodeJul 13, 2020Guru
> don't block anything your DNS thats on a server. [...]Sounds to me as if the agent didn't understand that the problem is
not with DNS itself, but with setting the DNS server option on the C6300
modem+router.The question is not whether their network is blocking anything (DNS),
but whether their provisioning of your C6300 prevents you from changing
its DNS server settings. Some low-level support flunky may not know
this, so you got the answer to some other question, instead.> [...] i[']ll either buy another modem or wifi router that[']s not from
> netgear.A cable-TV-type ISP has an amazing amount of control over the devices
which are connected to its network. Much of that is related to DOCSIS,
not Netgear, so I would not bet that changing vendors would help.
Changing to a separate unit for the cable modem might help. The DNS
server choice is a router question, not a modem question, so a separate
router would be more immune to goofy ISP policies limiting its options.
