jadedthang
May 26, 2019Aspirant
Can't connect gaming consoles or Amazon Echo Dots via wifi on C6300
Model Version: C6300 Firmware Version: 2.01.26 OS: Windows 10 ISP: Cox I can connect my pc's, laptops, and cell phones to wifi with the C6300, but I cannot connect PlayStation 4, Xbox One, or ...
May 27, 2019Guru - Experienced User
How are you trying to connect the game consoles? Wired or wireless?
jadedthang
May 27, 2019Aspirant
Connecting wirelessly.
- FURRYe38May 27, 2019Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Whats the distance between the modem and these consoles?
Do they connect wired to the modem?
